10 Bit supported resolutions
I assume that shooting video in "Raw", you mean LOG. Normally, a video shot in LOG will be very un-saturated, with weak colors. This is said to record better color gradation. The colors are then boosted in your editor. In the camera's Style setting, you can adjust the amount of Sharpness, Contrast and Saturation (in that order). If I'm shooting in LOG, I set the Style to Manual, -2, +3, +3 to minimize the correction required in post. If you are shooting 2.7K/30 or 4K/30 in H.265, this should produce a 10-bit video file that requires only a slight saturation boast. Also, White Balance on a sunny day usually looks best at 5600K. I hope this helps.
thanks heading out this morning
drnd
