Repeat flight
Farmflyer
Hello all,
I have an evo 2 pro that I use for work. I fly out and take a series of pictures (about 10) I would like do the same thing once a week but instead of having to fly it manually and take the pictures manually can I just have it repeat what I did the first day or time?
Thanks,
Rick
Reactions: ADOC
Hi @Farmflyer, you will just need to plan a mission flight using waypoints. From the splash screen where the Explorer app shows "Camera" or "Mission", choose Mission and then New Mission > Waypoint. You can then create your mission and set your camera actions (Take photo) at different waypoints along the flight route along with the camera/gimbal heading.
Here is a video on this:
Forgot to add, the "Mission recording" option is also in option your case. You can fly the mission you need and record it so that you can repeat that mission. The camera heading saves in the recorded mission so it's repeatable.
Can you do this with video? I'd like to use smart orbit, create a 360 video and then repeat with the same GPS coordinates. Is this possible?
Reactions: ADOC
shokzdiamonds
