Need some assistance with WebODM and 2D ortho creation
verticalflyer
I'm having some issues with a mapping mission that I ran (evo 2 pro). I've mapped out several places before without issue but made sure I was using a 80/80 overlap. This specific mission was to cover a small "ghost town" and the area was rather large so I went with the recommendations provided here: ( Tutorials — OpenDroneMap 2.0.0 documentation ) and flew two missions with a 20 degree path difference (260 degrees and 280 degrees) with the 280 degree path having the gimbal at 85 degrees instead of 90 with an overlap of 42/42 on both missions. Per the directions posted, that should give the equivalent of 70/70.
My problem is is that only the very center, to slightly south, part of the ortho was generated, leaving a huge chunk of the north part of the town non rendered. I've tried upping the min-num-features to 14000 and the matcher-neighbors to 14 but the end result is exactly the same. I'm at a loss here. Anyone have any insight into what I can do to get the rest of the ortho to render properly? I ran the dataset through Pix4Dreact, since they gave out a free year license with the pro, and it rendered just the center road of the town but not the forest.
Thank you. I've had no issues with flying just a single pattern with a decent overlap but this was an experiment and pet project. I was going to follow up on the odm forums if I felt pressed enough to create another account on yet another website. Figured I'd try here first to see if anyone had some insight.
I use WebODM all the time and I have never used the 20 degree offset. I only stumbled on that when I was digging in the documentation looking for VPS hosting. As I said, I have never seen that suggested in other forums (Pix4d, etc). Maybe some day I'll try it for kicks on a smaller project. It's just another battery. In fact I'm just getting ready to lad another 450 pictures in, all with 90 degree.
Hey @Bobstaff , have you checked out the new Oblique missions yet? I'm a bit tickled, and happily overwhelmed, by the options given by.
Well you caught me off guard. I just looked at the update and I'm a bit disappointed that there is no documentation for it. Looks like a bunch of test flights to figure it out. And at first glance it doesn't look like any oblique pattern I've ever flown.
I'm with you there on the lack of documentation. I put in a support ticket to request some info on so hopefully they come back with at least a bit of info. The new mission came out of left field but has some potential.
in84
