Issue using a DJI KLM file in a polygon mission.
z_bryant
I received a KLM file for a construction site mapping project, from a service company that only deals with DJI drones. It turns out the KLM was only waypoints that define the boundary of the project. I see no way to use that KLM to create a polygon mission in the Explorer APP.
I've never flown DJI's so I have no idea if this is normal or not.
The site in question is in a block of woodlands, so there are no visible means to see where the property actually ends. So, no way to build the polygon ahead of time.
Is there a solution somewhere that I'm overlooking?
I was up 'til 1:00 in the morning to come up with a workaround. It wasn't a very elegant solution, and somewhat of a pain in the butt. But I got a workable KLM with a grid in it.
I guess that for a lot of sites, this isn't an issue, as you can easily see the extents of the worksite. But what are you folks doing for similar situations as what I encountered?
You can import a KML file to create a mission in the Explorer App. I copied some text below I found.
KML File Import
Now users can create missions with their preferred KML planning software and import them to the Explorer app. The import feature supports:
  • Waypoint Mission
  • Rectangular Mission
  • Polygon Mission
Before importing KML, users need to save the files to their mobile devices. There are two ways to use the KML files:
  1. Open the file directly
  • Find the KML file and tap it. The Explorer app will the KML file automatically
  • Choose the correct mission type, and you will see the mission
2. Using the import function in Explorer app
  • Go to Mission, and find the import icon
  • Tap to choose the KML file you want to import, and you will see the mission
Reactions: altangerel
Problem solved. It turns out there is a maximum limit of 50 vertices, and the file I had used 63 of them.
I had tried it a couple dozen times or more in different efforts. Using a modified file, a donor file made by Autel, etc. Once in a while I'd see something flash on the screen before it went back to the prior screen. I'm guessing that was the warning about 50 vertices, but a bug doesn't allow it to show long enough. It was just by chance I saw the warning when doing something else.
Dajofa
