GPS data in AutelSky?
Where is flight GPS data in AutelSky?
Are you talking about the Flight Logs? If that is what you want it is under Personal Centre, but there is no way to export the logs as of this moment.
While flying you only get the bars diagram, not the actual number of satellites that are connected and logs from Autel Sky aren't compatible with Airdata yet.
Sorry I was not clear on my request. So I can properly log my flights (Part 107) I need the latitude and longitude of the take off point. The Altel Explorer app for the EVO II has that data on the map of the flight log. The Altel Sky app. for the Evo Lite + does not appear to show those coordinates Thanks - P
/sdcard/Android/data/com.autel.autelsky/files/FlightLog
no documentation found for how to parse the data.
You can find the following strings, among others:
locationName
maxAltitude
startFlyLatitude
startFlyLongitude
timeZone
videoCount
videoTime
altitude
bottomRadarInfo
dronePitch
droneRoll
droneYaw
flightSpan
frontRadarInfo
gimbalPitch
gimbalRoll
gimbalYaw
mLeftHorizontal
leftRadarInfo
mLeftVertical
offLineDuration
param1
param2
phoneHeading
radarInfoTimeStamp
rcButtonState
rcModeState
rearRadarInfo
mRightHorizontal
rightRadarInfo
mRightVertical
topRadarInfo
xSpeed
ySpeed
zSpeed
alertArry
alertCount
backTime
batteryCapacityPercentage
batteryState
batteryTemperature
beginnerModeEnable
cameraMode
cellCount
currentCurrent
currentElectricity
currentJourney
currentVoltage
designedVolume
droneDistance
distanceFromHome
droneExtWarning
dronewarning
flightMode
fullChargeVolume
gearMode
gimbalwarning
goHomeAltitude
lowBatteryWarningThreshold
maxError
maxFlightAltitude
maxFlightHorizontalSpeed
maxFlightRadius
mMode
numberOfDischarge
obstacleAvoidanceEnable
param3
param4
param5
radarEnable
rcRSSI
remainPowerPercent
seriousBatteryWarningThreshold
speed
timeLeft
visionErrorCode
visionExtWarning
visionWarning
voltageOfCells
droneLatitude
droneLongitude
gpsSignalLevel
homeLatitude
homeLongitude
remoteLatitude
remoteLongitude
satelliteCount
latitude
longitude
imageName
shootAt
recordAt
timeSpan
videoName
The records seem to be seperated with the string "Record4"
I see what looks like battery voltage slowly dropping during the flight
4316,4320 (4.3v?)
down to
2735,2904
The autelsky app's 'find my drone' feature wont show gps coordinates without installed google maps.
It would be helpful if autel would tell us the record format of the flight logs.
There is a tool to view flight log data,
Flight Log files viewer & converter to the Google Earth tracks
video instruction - Autel EVO 2 flight logs & Google Earth
link to download - aeflr.html
This tool show many data from flight log, but not all.
In my case showed data (and generated kml) are shorter then fligth time. It seems for kml used some part of data in flight log.
Dave.Samuel
