Good Evening.I broke my Evo 2 pro v.1 controller antennae today...Model EF7-1, looking to get it fixed or replaced.....have looked for an hour ..help.
are the stock antenna for the rc the same as for the sc?
are you ready to upgrade your rc to alientech, now might get a good time.
The standard RC that came with the non Enterprise V1 aircrafts has fixed foldable antennas, if these are broken I think it's time to buy a secondhand V1 RC from someone that lost the drone, this might be less complicated. Else do a crash course in soldering fine electronics. If you can get the standard screw-fittings on your RC, you then could buy new V1 antennas like those for a Live Deck or the Smart Controller. Those antennas should be more powerful as a bonus. Or even think like ken, and go to next level with alientech.
for example the V1 type antennas are available via:
Adorama or Madison
Hi,
1. just buy spare RCv1 on ebay - the most simple way
2. If you would like to fix your drone - no soldering needed. You need:
- IPEX to RP-SMA Female Pigtail Cable
- RP-SMA antenna
- T6 screwdriver
- PH00 screwdriver or similar
Examples of kits:
RP-SMA pigtails with antennas:
RP-SMA pigtails only:
SMA pigtails only:
How to modify RC:
Reactions: EBEPLS
Can you post a photo of what broke? I replaced my stock antenna with a 4 Hawks antenna and I should still have the parts it replaced.
Hi, thanks for the post.
I broke it at the pin location, so half the pin is missing...have currently ( shamefully), glued it, however of course it only sits in one position....but i have jobs to do and need to find a quick fix and a long term solution. Was hoping that i could fix or find another controller to purchase...however I am told that it has to be an exact model # match and I seem to be an Ef7-1 and most are EF7 only....Could buy a new drone but really love this one....has been a workhorse for two years now with minimal issues...
I have V1s so I assume the antenna would be the same. I found this pic from when I installed the 4Hawks. Now I just need to find the antennas. I'll look tonight, and let you know.
EDIT: I went to look and found them more quickly than I thought I might. Here are some add'l pics. Do you think they're a match? There are two diff versions; left and right. The wire on one is longer than the other.
Reactions: uas_gian
HI, thanks so much for looking, they appear to be the same, however I am now thinking that maybe is should replace them with a better product.. My apologies for having you look for them...I am researching antennas currently to buy the best product.
Dave.Samuel
