EVO Max 4T Metadata issues
dspiegel
California
I am trying to upload photos into Pix4dmatic and its getting an error. This is due to the camera calibration being incorrect. I have attached the metadata from both a DJI and Autel and the Autel data is missing a bunch of information. Anyone have any success flying a photogrammetry mission? Pix4D provided the following:
I hope Autel fixes this issue.
  • Meta Data Differences.pdf
Find a Metadata editor that does batch changes.
Change Horiz CS to EPSG:4326 to indicate WGS84
Don't change the original images. Copy them and then edit the metadata.
This is my guess on this. All drones (Non-RTK/PPK) will use WGS84 and the correct EPSG would be 4326.
Reactions: dspiegel
I am surprised that Pix4D Support didn't tell you to do this.
They are usually very helpful.
They told me to contact the manufacturer to get help removing or replacing the tag. I didn't know I could edit the metadata myself as you proposed.
They identified the issue but didn't clarify what the tag should be.
I have used Metadata +++, but I have never used it to do a batch change.
Here is a Youtube video on doing a batch.
Thank you. Ill try that one out. I wish there was a way to edit it in the drone itself so I didn't have to go through this but Autel has been pretty slow in responses.
in84
