EVO II Pro Losing GPS signals during flight
cneufeld3
Hello,
I have an EVO Pro II V3 RTK that is under a year old, which sometime loses the GPS satellites during a mission. I sometimes restart the aircraft before a flight to get it to 'see' the GPS signals. I use the RTK on the local CORS/NTRIP network, so it doesn't fly away, but this can't help the positional accuracy.! I have reached out to Autel Robotics, but I have read their support is not good, and wanted to see if anyone in the community has had a similar issue that was resolved.
Thanks.
UPDATE: I did get a response from Autel, which was basically to remove and reseat the RTK module. That seems to have worked, but I have only done a couple of flights since.
Same model, Same results for us. Ours also fails to track satellites during flight when RTK is off. So it is not capable of following flight lines or a mission. We swapped RTK modules with a V2 and that fixed the RTK issue, but not the internal tracking, so it still fails to do missions. Rather Frustrated. No solutions yet.
in84
