Hello.
In order to do some Photogrammetry, I need to know the size of the sensor (in mm) of the 6k camera in my EVO II Pro to calculate the Ground Sample Distance of my orthomosaic. I have seen already that it is said in the app missions but I want to be sure.
I have found that EVO II Pro camera builds a SONY IMX383.
Please, could you confirm me that is this the sensor built in the 6k camera, please?
If Sony IMX383 is the sensor, there is something that I do not understand when checking the specifications within the SONY product information sheet (attached).
It says that the pixel size = 2,4 µm.
With a maximal sensor size of 5472 X 3648 pixels, it only reaches a dimension of 13,1328 mm x 8,7552 mm. These dimensions are far from the 1" size it is suppoused to be, isn´t it? An inch is equal to 25,4 mm if I am not wrong.
I expected to find a 36x24 or 36x25,4 mm full frame sensor.
Could you explain what am I doing wrong, please?
Greetings,
Ignacio
Greetings,
Ignacio
