have ever to ask to autel engineer Can't answer it. So mean I must to find that part before.The original battery has data lines and it communicates with the drone, so just supplying power will not work. Batteries are no longer available, so it will be very difficult to get it working. Not impossible, though, if you are able to reverse engineer the data lines and fake it out, but I'm not sure anyone has done that.
That's difficult for me, I'm in Thailand. Just found only one x-star user and he very busy.Autel will give us ZERO support, and I've asked. So any and all support will need to come from us X Star owners. The best way for you to try to get flying is buying a used battery (likely will be dead) to extract the BMS, and replace the cells. It still won't give you full capacity until you reset the TI bq3055 chip, but you should get something.
Direct battery to camera, How to? Can you suggest? and can sent signal to the phone?You can try using the camera with power direct to a battery, but it won't fly. It's not compatible with the Phantom.
