When I go out to one location (two to three times a week) I run three seperate waypoint missions across two batteries. Today I got out, flew the first mission. No problems. Loaded the second mission, it flew to the starting point, flew about 3 seconds and stopped. A message popped up on the screen, but I couldn't make out what it was. Restarted mission, same thing. Brought it down, power cycled everything. Started mission, flew back to the starting point and same thing, stopped after three seconds. Started trying to fly it manually, but it's hard to do because from point A to B the drone is supposed to be pivoting the whole time. I also noticed as I was free flying the drone would pull up suddenly like I did a hard reverse.
Landed. Swapped batteries. Started third mission. Same thing. Then I took off obstacle avoidance and it flew the mission with no problems.
Called Autel and they said they've seen this before where obstacle avoidance in bright sunlight can see glare as a solid wall. I've flown in similar conditions and never seen this before. Has anyone seen anything like this?
//Gonna try to fly this weekend at a different time of day and see if it works out.
