The end of the USB Mini cable which connects to the Evo Controller is tapered. The USB Mini Port on the controller used for charging is not. Because of this, it seems that the issue found on this video may result on the Evo Controller having the same problem:
There is no information on this on the Evo manuals as to how to correctly insert the cable. I grabbed a screen shot from Autels video where they quickly connect the cable to the controller. Since the port isn't tapered, it's hard to determine which end of the cable plug needs to face up.
Why both DJI and Autel still use USB Micro instead of type C is odd.
Nevertheless, do you guys mark the end of you USB Micro cable to remember to insert it correctly and not damage the port?
