Actually was having great results with steady horizon the last several months...then I upgraded my firmware. Uploaded the latest firmware earlier this month and ever since I've had a consistent, steady camera tilt to the left. So, I went to calibrate the gimbal and got a "failure to calibrate". I've tried calibrating probably more than a hundred times now, on wooden floors, on marble floors, on a table, with stock filter on, with Polar Pro filter on, with no filter on, no matter what I do the Evo gimbal will not calibrate. And researching retrograding the firmware I've learned Autel won't allow that. WTF? For just a split second when I hit "calibrate" on the app, I get a warning that "Evo is still vibrating", then it launches right into the calibration process. But the warning is only there barely half a second; had to see it multiple times in order to read the full sentence. And there is nothing there to vibrate the Evo except the internal fan. Any ideas?
As for the horizon tilt, it's there constantly. When I start up the Evo on a flat surface, the camera comes on tilted to the left. I'm able to correct it with the roll adjustment, a setting of -1.6 gets it to zero, but coupled with the inability to calibrate the gimbal I'm really displeased with Evo right now. Anyone have suggestions, or experience the horizon tilt after latest upgrade?
Max
Max
