Strobe light question
nh phantom
For those of you that are using 2 white, 1 red and 1 green strobes . What orientation are you mounting the different colors. front colors? rear colors. right and left? Thanks
since I don't fly with strobes permanently attached, I sometimes find it hard to remember the setup. take a look at the photo for the red/green orientation on the front. these strobes are plenty bright, one white to the rear is sufficient.
Thanks. I too do not leave the strobes installed. The Firehouse Arc V lights are hard to tell what color they are. I'm toying on making colored mounts so its easier to tell what color the lights are but the mounts are going to be a left or right side. I think anyway.
will you post a photo with these mounted on your Evo II?, and also a link to where you got them?
I am interested in how others are using these as well. This is my setup; green on right front, red on left front, white on back and bottom.
^is that your only battery or do you have velcro stuck to every battery?
I think you may have already found this out but having two white strobes in the rear is probably overkill and not really necessary.
Yes I have a piece of velcro on each battery.
The green and red are not as bright as the white, so if (when) I occasionally lose sight of the drone, I simply hover and slowing yaw until I see the white facing me. So I find that helpful.
redwingaerials
