Need some help guys. Have a smart controller and everything seems to be set up correctly except a language issue. In the setup the language is set to English and everything works as expected. However, I have set my C1 button to switch from standard to ludicrous mode which it does. My problem is at the bottom of the screen the prompt that tells you what mode you are in is in Chinese. Anyone have a solution for this? Thanks for the help.
