Satellite Beach Florida Sunrise
kdub2051
Some HDR shots with EVO early morning at Satellite Beach FL. Edited using Cyberlink PhotoDirector 9. ISO 100; Freewell ND16 and ND32 filters.
Very, very nice! Man, have I spent a lot of time at a hotel there (Ramada on the beach?). A long drive to the Cape, but quieter than staying in Cocoa Beach with all the rockets scientists and wannabes. ;)
That's amazing. Are you using Photoshop to do the HDR processing?
I'm not getting good results. I need some tips.
I put the same set of photos through this (it's not free, so the finished product is watermarked):
Fotor
and got much better results than I got with Photoshop.
Edit: I just noticed that the video I took at the same time I took snapshots has MUCH better color and exposure.
So I clearly have more to learn about proper camera settings.
I do like the photos but I also find there is a large amount of noise in the photos. Just for fun I ran your first one through Photoshop and used a plug in called Topaz DeNoise 5
Do you think it looks better or worse?
3978
Reactions: HiloHawaiian
Better. While you always loose some fine detail with de-noise filters, many times it's worth it. At print-on-the-wall viewing distances, most won't notice the loss. Low-light shots like this using small imagers always have noise in neutral-density areas & shadow areas. The only decent way to partially clean it up is to despeckle/de-noise a bit. The only method I know to get less noise is to use a camera with a big imager. My Nikon D810 is a brick to carry around, but if you want less noise & more dynamic range in these kinds of settings, that's what you need (or the equivalent Canon, Sony, etc.)...
