Please willing owner of a paid version of DaVinci to render a difficult file (see sharing). If the resulting video was "OK" (without jerking the image) I would decide to buy a license. Thank you!
very cool; well done. you took an otherwise ordinary video clip and really spruced it up nicely. i'm inspired (to go back and look at all my regular clips). wish my workflow was that fast, i barely got his video downloaded, lolI tested the footage with my DR Studio edition and went through my usual workflow; the video plays back perfectly for me after rendering it out. I uploaded it to YouTube so that you can see it on YouTube. As I am posting this, it is still processing the HD version, so it could take a few hrs to see the 4K version but it plays fine on my computer.
You can also download the final video and test it on your computer via the link below. Since my website has limited space the link below will only work for 7 days. The YT video is just to show you it works on YT, so I'll probably remove it from YT in a few days.
I can't guarantee however that you need the Studio edition to fix whatever is wrong with your output. When Davinci Resolve does not support something it simply plays the audio but won't show the video such as if you were to import 10bit footage into DR when you have the free version. If you can edit footage in DR, then it will properly render out the footage unless something else is wrong such as your settings, video card driver, codecs, etc.
Download Link
https://vumediagroup.com/jobfiles/NanoTest.zip
Thank you very much for your willingness to help in my long (so far in vain) fight! I've watched both of your videos and I find them satisfactory. I've done many attempts and configuration settings, but I don't like the results. I was considering buying a license because I read that the free version does not support GPU processing. But that's probably just a matter of processing speed (isn't it?). But speed is not important to me. I made the last attempt in the settings for YouTube. I took important pictures related to the configuration and I send them in the hope that you will look at them and evaluate whether the settings are correct or whether there is a forgotten / other one. My English is the work of a translator, so I apologize.I tested the footage with my DR Studio edition and went through my usual workflow; the video plays back perfectly for me after rendering it out. I uploaded it to YouTube so that you can see it on YouTube. As I am posting this, it is still processing the HD version, so it could take a few hrs to see the 4K version but it plays fine on my computer.
Download Link
Nice video.
The Studio version renders much faster by using the Nvidia encoder.
You can smooth out the too-fast pans by cutting speed in that section to 50% and using the "Optical Flow" option in the Video Inspector "Retime and Scaling" section and "Enhanced Better" Motion Estimation. This interpolates frames between the frames. It's very slow to render (even with Studio) but amazingly effective. Optical Flow may not be available in the Standard version of DR.
