I'm also a long ranger and fly mostly in the same area every day (288h flightime and 8.000Km), but I couldn't try the
Lite+ myself because I had to return it to the dealer as the gimbal briked during the initial firmware update, so I couldn't even try a single flight.
I've been flying with the Mini 2 and the Air2S for a year and a half, both of them with the FCC hack. There is still no FCC hack for Autel, so I know for sure the
Lite+ in CE mode will perform way worse that what I'm used to (range and signal quality).
On the other hand, Air2S had less range than the Mini 2 at the beginning, it needed a few firmware updates before it started to work well and on the battery side, it just stays in the air for about 17 minutes if you travel a lot, and never goes past 22 or so while hovering.
Lite+ has way more juice.
Maybe Autel transmission doesn't perform as well as OccuSync, but at least Autel doesn't sell you to the authorities like DJI does with their DJI Aeroscope systems, which are quite popular in my country (I switched to Atuel mainly for that reason).
Let's see if my second
Lite+ doesn't come faulty and can say goodbye to my DJI drones.
