Problems with case and antenna
Edwinpilot
Hi pilots I writing from Peru
I got an autel evo in an auction, however this when I arrive I present 2 damages.
1- The right and left sides of the case were cracked.
2- The control antennas were broken.
i just looking on internet if I can find a new case to replace also a antenas.
Do yo know where I can find the case? Also do you recommend to chance de antenas to a 4 hawks? How much increase de signal?AF3CC4B6-E7B8-4464-91D5-215059593692.jpegC6F780BA-7C06-461C-A962-78C27D32A261.jpeg52DDAE64-B7F4-4CF8-A555-F77D1D738256.jpeg
thanks
Edwin
Hello
the hull of the evo is also slightly cracked on mine for 1 years.
You do not risk anything to fly with.
For antennas contact autel custommers service .
Hello
Thanks, i just bought this
HUACAM HCM82 2X 8dBi 2.4GHz 5GHz 5.8GHz Dual Band Wireless Network WiFi RP SMA Male Antenna+2x15CM U.FL/IPEX to RP SMA Female Pigtail Cable Amazon.com: HUACAM HCM82 2X 8dBi 2.4GHz 5GHz 5.8GHz Dual Band Wireless Network WiFi RP SMA Male Antenna+2x15CM U.FL/IPEX to RP SMA Female Pigtail Cable: Computers & Accessories
But. I will contact autel evo support
Autel Robotics does not provide warranty to Perú. You will have to cover the costs for shipping. Your best bet is to install the antennas you purchased and continue flying. Like Franlac said, the cracks on the side are not structural and should not give you any troubles.
Yes that why I buy the drone, to share with friends about a autel evo.
Well since I have to use the drone tomorrow I find a guy than print on 3D, he made this for me
I guess it’s working good, the only that I think is that we have to put a needle, I don’t know If this make interference or make problems.
I also need a recommendation, should I buy the hucam antenna or 4 hawks antenna. The difference is for 100$ but I don’t know if the result is the same or diferent.
thanks
If you put a pin, make sure it's not made out of metal. As for the antennas, it really is up to you. If you are interester in bidirectional range, then get the 4hawks. If you want omnidirectional range, then get the hucam. I find that the default antennas get plenty of range. I do suggest you read up in current drone laws of Perú.
Thanks, the pin I use is made for metal. What will be the problems with this?
which is best bi or omni?
A piece of hardwood toothpick or a small fiberglass rod (found on DIY or kite sites).
Otherwise the best solution, an 8 Dbi antenna graft (or 10 Dbi as I put on mine) more solid and you can remove to slide in the bag. (I only remove one of them, the other can remain vertical)
chuckster58
