Problem Naming Missions using KML Import
Malli35998
Kingwood, TX
Website
www.raptoraerialservices.com
I am running the latest verion of the Autel Explorer App. Pad_V1.0.92.
When I use the KML Import option to create a new Mission, I cannot create/modify the name for the Mission. Every single time I hit the pencil icon I get the message "Autel Explorer has stopped ... Open app again". I can work with the Mission but cannot name/rename it. If I create a Mission from scratch (not using the KML import option), everything works fine. I have had this issue for a few Autel Explorer App versions. Thoughts?
I have found that first I name mission then save and close then open mission again ang name is OK in the first frame that showes all the missions, but the field where you type the mission name still does not have the name. not sure why but Autel have created a very stupid App that does not work. Autel also do not recognise this as a bug that needs fixing.
Elio-Italy
