- Joined
- Oct 15, 2020
- Messages
- 4
- Reaction score
- 2
- Age
- 42
Hi.
Recently i encountered very disturbing behaviour with Autel Explorer (hereinafter referred to as AE) - it appears to be occasionally unusable without an internet connection.
I discovered it when i attempted to fly after a longer pause. App displayed only picture from the camera, but no telemetry or control from applicaton. At that particular point i was just blaming it on a recent AE version upgrade that i didn't test-fly after installing. However later tests with another android device with older version of AE showed the same symptoms.
Further tests showed that it happens only after a certain pause in usage and when the android device has no available internet connection (or if the network is restricted for AE). If the internet connection is present and the full working connection between the app and the controller has, at least once, been established then from that point forward it works for an unknown while even without the internet. Also it will work on other android devices for that unknown period.
Tried to remove and reinstall the application while having the issue. Same result.
AE Downgrade. Same result.
However during this time, when the app is misbehaving, the drone itself is operational using the remote only. Not very comfy to use, though.
To be 100% sure that it's the internet i replicated the issue by terminating all networks (Wifi, LTE) on the phone and connecting it to the controller after couple of days of not using the drone. Picture came on, no telemetry. As soon as i restored the LTE connection AE was fully operational within few seconds. After that everything worked on all android devices with or without internet - no problem.
The app and the drone are at the most recent versions (2.7.25, 1.1.8.0).
Has anyone else experienced the same issue? Or is anyone willing to test this and see if they will have a similar result?
