I have a problem...The other morning I wanted to capture a beautiful sunrise from my back yard..it was still morning twilight ( partially dark ) and I setup with my landing pad in the backyard near my greenhouse. I turned the controller on and was not going to use my phone and then went to the pad and turned on my Lume Cube Strobe and then the battery. I set it down as usual before turning the battery on. I went back to my controller and started the evo and lifted off to allow it to see it's location and then I pushed the stick forward to move the drone to a clearer area a few feet away, well this is where stupid me comes in...I had set it down on the pad with the camera facing me instead of away as it should be because it was still a bit dark outside. When I pushed forward it naturally came back towards me and hit the side if the greenhouse and flipped. I should have paid attention to the forward lights but did not. Two propellers were stained with grass and everything else was normal. I replaced the propellers. When I took it out to an open area today , a display on the controller said " Motor Spinning ", I had never had that display before. I guess I messed up a motor or need to check something else, I hope not. HELP!!!!! Sorry for such a long message.
