Mapping speed
bseasmd
Hi folks,
I'm having trouble with the mission planner, primarily that I can't seem to set the aircraft speed over 2 mph.
Has anyone had this issue and know of a fix? I'm going to be in a bind if I can't sort this out!
Thanks in advance!
We've had that happen when the format changes from JPG to RAW (DNG). The files may be too large to copy to the micro-SD card.
Ah ha! I was shooting RAW ± JPG, which might be the problem! I'll try JPG only and see what shakes out!
Whats your mapping altitude are you trying to do? Have seen lower speeds for lower alt, higher speed for higher alt.
redwingaerials
