Internal Pictures of Autel Smart Controller
alsey7
These are pictures of Smart Controller... looks like maybe Autel can replace the radio chipset since its on a separate board also located the lost sd card slot
Looks to be a quality piece of work. Should last a long time and the battery can be replaced if/when needed. Wish I could afford one but I really don't need it for my hobbyist level fun. Would still be nice though.
Great pics, thank you.
Did you see if the explorer app allowed the card slot to be used as a storage device, or is it only "seen" in android? I assume the card reader is located below slightly centered from the antenna, above the blue writing on the board? Anyway to access from the exterior?
yes u can install a sd card and it will work. only way to acess it from outside is make a hole LOL
  • Wow
So does the case show where a cutout should be, or possibly a mold made without the cutout. If you were to carefully cut the case, could you insert and extract without problems?
chuckster58
