- Joined
- Jan 17, 2020
- Messages
- 19
- Reaction score
- 11
- Age
- 73
I am relatively new to drones, flying about six months and am trying to learn everything I can to fly safely and stay out of trouble.
I'm making this post to inform others of the rule concerning the lack of a minimum altitude for helicopters.
I just assumed that helicopters were held to the same standards as fixed will aircraft. I was wrong ?.
Sorry if I am the only person on the planet that didn't know this reg. just wanted to put the information out their for others like myself.
I called to report the incident I'm describing, it occurred on the 20th of Feb.
FAA representative returned a call to me this morning regarding an incident that occurred last week while flying my EVO in the area of my residence.
What happened: Flying to see the sunset and make a visual check of my neighbors property (snowbirds).
Returned to home decending from max altitude to approximately 70 ft to clear power lines to enter my property.
Suddenly from the SW a military Chinook helicopter flying low level at approximately 250 to 300 feet and 125 knots enters the airspace I had just left about 10 to 15 seconds earlier.
This could have ended badly. Personally I believe this is a hole in the regulations that allows for potential deadly incidents.
So, here is the FAA rule. Pay attention to Para (d) (1) and (2)
Sec. 91.119
Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
(d) Helicopters, powered parachutes, and weight-shift-control aircraft. If the operation is conducted without hazard to persons or property on the surface--
(1) A helicopter may be operated at less than the minimums prescribed in paragraph (b) or (c) of this section, provided each person operating the helicopter complies with any routes or altitudes specifically prescribed for helicopters by the FAA; and
(2) A powered parachute or weight-shift-control aircraft may be operated at less than the minimums prescribed in paragraph (c) of this section.]
Sec. 91.119
