- Joined
- May 1, 2023
- Messages
- 3
- Reaction score
- 0
- Age
- 37
I left my gimbal cover on when starting up and now the camera picture is blurry, please help, did I mess the camera up?
Send it back as warrantyI had been flying it before this happened everything worked fine and looked great. Then I went to go put it away and my Dad came outside to check it out. In a haste I got it back out and turned it on while the cover was still on (stupid I know). I took the cover off while it was still on, and it was in a limp position so I turned it off and then back on. I then had to reset the calibration from the controller, the camera went back into position and can turn and zoom fine, but the picture is blurry seemingly out of nowhere. I tried switching to from AF to MF and then back again but the problem is still there. I just got the drone last week so this seems really weird. I emailed Autel and am awaiting their response. is there a way to reset the whole drone and see if this problem still persists?
I've had a smudgy filter screwed on an that def caused the image to be softI left my gimbal cover on when starting up and now the camera picture is blurry, please help, did I mess the camera up?
I have never heard of that, I have left mine on once and immediately turned off the drone....there was no damage done to my EVO. Check to verify that the AF is still set to auto and didn't somehow switch to MF, or try changing to MF then back to AF, that's the main thing that causes a blurry picture. You can also try a gimbal calibration but I don't see how the gimbal could cause a blurry camera.
Hi AMI Aerials, Did you ever find the cause, and solution, of your sharpness issues. I'm a new owner of an Autel EVO II Pro V3 myself and not happy with image sharpness. ThanksI left my gimbal cover on when starting up and now the camera picture is blurry, please help, did I mess the camera up?
I had to send it back and they replaced the cameraHi AMI Aerials, Did you ever find the cause, and solution, of your sharpness issues. I'm a new owner of an Autel EVO II Pro V3 myself and not happy with image sharpness. Thanks
Thanks for sharing that. I know every case is different, but just to give me a ballpark anticipation for budgeting, what did they charge?I had to send it back and they replaced the camera
