Do you have to calibrate the gimbal after a hand launch? can't you boot the bird on a balanced surface first, then pick it up?just hold the evo level in your hand
start the motors and lower the evo a few inches and the motors will detect an altitude change and will spin up enough to launch
no need to calibrate the gimbal,and NO you cant lift after having the motors started,doing so will make the motors spin full speedDo you have to calibrate the gimbal after a hand launch? can't you boot the bird on a balanced surface first, then pick it up?
Hmmm great way to loose a fingerno need to calibrate the gimbal,and NO you cant lift after having the motors started,doing so will make the motors spin full speed
