I have or had a similar problem with EVO 2s. My batteries would overheat near the end of the max flight time. This is when the batter is at its hottest temp. But instead of simple battery damage, the entire drone just shut down. I purchased another
EVO2, as Autel would not cover the 1st crash or (fall out of the sky). They never hold up there warranty. They always find a loophole. The second
evo 2 had the same battery issue. It's power shut down over a lake. It took me a week to find it , using DJI drones with polarized lenses to see under the water. I found it a week later, went for a swim and retrieved it. It's ruined. The warranty , again , is not being honored by Autel. They found another loophole to deny my warranty. Anyway, because Autel has pushed their drones to manufacturing limits, it does not mean they were meant to fly in such a manner. If flying in any temps greater than 85 degrees and high humidity, you will need to give the
evo 2 rest hovers and watch the battery temp go down intermittently. This is especially the case if flying in Ludicrous Mode. At 140 F the battery will become unstable. It may get damaged, fuse to the EVO battery pin connectors or simply shut down. The only warning the
EVO 2 app gives, is something like,' battery overheating, performance will be reduced.' however, this does not stop the battery's temps from continuously increasing. Eventually, If you don't get it landed, you will have a problem. If I ever buy another
evo 2, i will not use Ludicrous mode and I will not fly it for more than 30 minutes at a time. I also will avoid days of high heat and humidity and always check the battery temp in the Apps submenues.
