Flight Records Not Recording?
Bischofftep
Using iOS and Autel Explorer 1.4.18
Only one flight I've ever made has been logged in the Fight Records list. As it happened it's the second flight I ever made. No flights since then have appeared in the records list.
I've tried deleting the app and re-installing: that log is the only one showing up. Synchronizing does work, but still only shows the one flight.
Anyone else seeing this behavior?
-Doug
Hello Doug,
I was experiencing the same, not at the beginning then it stopped recording flights. Wasn’t until recently updating to 1.4.18 started to log all flights consistently. Hasn’t skipped since, don’t know what could cause yours to completely stop.
Hopefully someone experienced will chime in, I’m still learning Evo 2. This is my first Autel product, good luck and keep us posted when it starts recording flight logs.
Paul
Reactions: Flyhighdroneboy
I have the same problem I’m new here and have the evo 2 8k great drone I’m having great fun which sometimes helps 😃cheers from Ireland 🇮🇪
Elio-Italy
