First Flight
newdist
Saskatchewan
Weather finally changed and was able to take my first flight with the new EVO. My worst fears were realized when i got her up and checked the horizon ! Horrible tilt ! Am running a ipad mini and with the horizon touching one upper corner the other corner is down approx.2". I fly an xstar and a mavic pro and have no tilt problems with either one . What do i do now ? Cant sell it. No one in their right mind would buy it with the horizon tilted that bad ! Suggestions ?
Is it still under warranty? How long have you had it?
There is a guy here willing to change your evo for a mavic pro. You can try there.
Did you do the gimbal calibration through the app? Not the "manual horizon tilt adjustment" but the gimbal calibration.
I doubt the horizon tilt adjustment would compensate if it is as bad as you say.
That HAS to be done on a level surface! Some have suggested it needs to be done three times but I personally have only had to do it once.
If the tilt is THAT bad, you will be able to verify it before taking off by just looking at the camera view with the drone on and connected but still on that level surface
What firmware/app level are you at? The most recent releases did a lot to address the tilt but the calibration needs to be done anyway regardless of firmware/app.
Of course I trust what I was told by Autel with a grain a salt - due to so many people complaining about gimbal tilt -- but here is what they told me when I sent them video from Evo setting on my level floor -- unable to show it was level after the calibration:
3874
What is funny is I placed it on a tiled floor with straight lines -- the gimbal as it is moving up/down can follow one of the lines on my floor every so perfectly straight -- but yet -- only to reset the camera and go right back to looking tilted/low on the left side.
And if the Evo does not think it is level - it will not let you calibrate. That is been previously mentioned.
Hi!
First post here!
Calibrating should help but make sure the floor is in fact leveled. I would suggest using a level to make sure that the x and y axis are leveled (i.e. bubble between the two lines).
this is what I was going to say, might as well celebrate the remote while you're at it, if it's never been done before.
Don't give up on it so quickly, there's far more good about your Evo than bad, if calibrating your gimbal doesn't fix it (which I'm betting it will), Autel will fix it. Mine has had a very slight tilt on occasion but it seems to self correct in a minute or two, I've never had to adjust the horizontal tilt. But i also calibrate on a semi regular basis.
Also, remember to take the gimbal lock off before you power up. That's an easy thing to forget about, I speak from experience!
Hi!
First post here!
My dinky torpedo level is one thing....always subjective as it is just a bubble and it is your decision what is or is not right..
But the torpedo and this nifty app agrees where I am placing it - to be as close to perfect as you can get.
Especially the app -- shows less than 1 degree difference any way I put it.
3905
3906
3907
3908
3909
3910
Oh, almost forgot one angle: The way my Evo is looking out:
3911
How's that for HOLDING one phone to take a picture of another -- lol
As I figured screen shots from the phone itself would draw out the skeptics.
Thank you.
Reactions: KevinP
Thank you.
That looks staged. Do a video next! ??
Reactions: thomasr
