Firmware Beta 1.5.34
RichL
Anyone download and use the Beta version 1.5.34 of the firmware for the EVO Lite? I recently contacted Autel because my EVO Lite + started to wobble on take off. When I landed it one motor was much hotter than the others so I figured it was starting to seize and needed a replacement. Karen from Autel responded that this was a problem in cold weather and was addressed with this firmware version (1.5.34) which is listed as a beta version. When I asked if there was issues with this firmware because it is a beta version, Karen responded that it addresses the issue with no other concerns. So, because I've had experiences with Karen before I need to ask if any of you have downloaded this firmware. If so, does it work without wrecking something else up? Thanks!
I flew yesterday and after I was finished the update popped up on my controller. I downloaded it to Lite Plus and put a fresh battery in and went back up to see if drone flew fine.
I didn't have problems beforehand so not much difference but it flew fine and did everything I asked on new update. Landed it put it away till next weekend.
I haven’t downloaded the beta Sky app. Do you mind sharing what is new in beta? Many thanks.
It is not the Sky app that I am asking about. It is the app for the aircraft. The drone would wobble in very cold weather. Apparently it is a known issue with a few EVO Lite's so they created this beta version to address it.
