- Joined
- Sep 20, 2020
- Messages
- 153
- Reaction score
- 55
- Age
- 55
I think its done. Calibrated the remote and gimbal. Just got to do compass outside in the morning. Fingers crossed.
I have not noticed this problem but I will look more closely at the video I shoot today. E2P specs say the minimum focus distance is 1m. I assume that your kitchen tests were over a distance of at least 1 meter. I would at double or triple that for bench testing. From Autel Specs:OK. so another batch of - non scientific - tests with focussing this morning, with the downgraded firmware. Nope, still blurred in the bottom right-hand corner.
I did an autofocus test first. Then a manual focus test, from Zero to Infinity. I marked the four corners with newspaper, kept the iso at 100, and waited 4 secs between each shot as I ramped up the focus from Zero.
Note. All of this is done in my kitchen, NOT FLYING THE DRONE, with the drone on a hard surface and the only thing moving is the gimbal.
I assume, as no one else has mentioned it, a corner soft focus is a rarity with Autel?
You will not notice it in video mode. Only in stills mode, if you have the same issue I have. Video mode crops the edges of the frame.I have not noticed this problem but I will look more closely at the video I shoot today. E2P specs say the minimum focus distance is 1m. I assume that your kitchen tests were over a distance of at least 1 meter. I would at double or triple that for bench testing. From Autel Specs:
"Focus Distance: 1m to any distance (with autofocus mode)"
As far as your drifting problem, I'll test that today as well.
That sounds like the right solution. I flew this morning and there was no, none, Nada drift. I only shot video. I hope you get a speedy response.You will not notice it in video mode. Only in stills mode, if you have the same issue I have. Video mode crops the edges of the frame.
I measured my kitchen area and it was 1.8m. the other tests I did were also outside set at infinity with higher shutter speeds. the edge blur was still there.
I have been confirmation of a replacement drone from the reseller so this one is going back.
Just wondering if you got to test this with the Viewpoint Flight Mode? Then you could rule out the possibility of minute stick movement playing any part in that drift.My phone was in airplane mode and yet the drone drifted off to the right. When reversing it drifted to the left and also lost a bit of altitude.
Hiya,Just wondering if you got to test this with the Viewpoint Flight Mode? Then you could rule out the possibility of minute stick movement playing any part in that drift.
Also regarding the hovering and drifting, was this over a neutral ground area with no metal and electrical interference potentials?
I'm just thinking of the things that have affected my birds in the past to behave similar to your experiences. My Evo 2 Pro is yet to arrive, so I have no experience with it as yet!
Hope it all gets sorted easily for you.
I wonder if you have paramagnetic rock like we do in the hills here? That plays havoc with electronics at times!Hiya,
I live in the Higlands of Scotland. The Evo was 394ft up in the air. The only nearest metal or magnetic or potential interference was the overhead small power lines some 1000ft away.
I tried Precision mode, Dual Stability and Standard mode, I never tried Viewpoint mode. When left to hover, the Evo would just keep moving to the right, like there was minute stick input.
When flying high or low, forward input would make the Evo drift to the right. When reversed it would follow the same course backwards following the off straight line it made.
I tried 2.3.3 firmware and 2.5.0 firmware both were presenting the same thing.
There was zero wind, conditions were amazing and yet the Evo acted like it had an inner ear infection and its balance was off.
The Evo has been shipped back and a new one is already en route to me.
Having seen my screen recording, the reseller and supplier both think it was an IMU issue.
I just watched them, I flew past the link to them in the original post thinking it was a quote! That is very noticeable indeed.Having seen my screen recording, the reseller and supplier both think it was an IMU issue.
Hi.I just watched them, I flew past the link to them in the original post thinking it was a quote! That is very noticeable indeed.
There are a LOT of settings! Go to the settings "gear" in upper right corner. Select Flight Control. Scroll down to Advanced Settings. Under Sensitivity you will see Attitude, Brake and Yaw settings. Fiddle with these, especially the Brake settings. I have my Brake setting at 200% and it still takes a while to stop and freeze. Good luck.Hi.
The new Evo II Pro has arrived.
Tested the camera in my kitchen. All seems well there. Sweet spot is f5.6 but anything from f3.5 to f7.1 is great. After that diffraction kicks in, but still usable. More importantly, f2.8 does not have a lower right blur. Phew.
Did a 30 min test flight but have not checked the stills and video footage yet.
Forward input relays to straight flight. Yey.
Though this is on firmware 2.3.3.
However, I must be doing something wrong as this Evo drifts as well, when hovering doing multiple overlapping stills.
The sequence is. Take a shot, move to right or left, no input on sticks and let the bird settle, then take a shot, the repeat sequence.
At the point of stopping and giving no further input the bird drifts, very slowly then eventually settles.
Could this be an exp setting?
Are you on Auto Focus (AF) or Manual Focus (MF)?I've been hearing about focus problem but never had one till yesterday - while filming all of a sudden camera lost focus and did not regain it till I press on a screen
I hate to say it, but it sounds like a problem with the camera. It should stay in focus. Have you tried manual focus?
No, it's a single case for now (as mani others ) if it happened again...I hate to say it, but it sounds like a problem with the camera. It should stay in focus. Have you tried manual focus?
I know it's a flying brick that behaves like an airborne lump of concrete, are you flying on the slowest settings when doing these captures? That would at least minimise movement. Maybe?Hi.
Hiya,I know it's a flying brick that behaves like an airborne lump of concrete, are you flying on the slowest settings when doing these captures? That would at least minimize movement. Maybe?
I can't say whether you are being too fussy or are cursed never to have enjoyable drone time! I can't actually see your experience for myself, just the video you share of that struggle.Hiya,
I have tried, precision mode, Dual stability, and standard mode. All in firmware 2.3.3.
Sadly the drift would happen after each time I tried to do a shot, then move.
Leaving the Evo to Stabilise it would drift to the right.
I upgraded the firmware to 2.5.0 today. The weird, flying straight drift to the right, happened again.
After trying various different methods to fly straight I gave up as it would not fly straight.
As there were people behind me I landed the drone and picked it up.
The people ended up leaving, so I tried again, and low and behold the Evo, flew straight. No matter what I tried it did what I told it to do.
So weird.
I hope this has now sorted itself, though I want to believe it, I do not have faith, that it will.
In addition to all of this, the focus is randomly off on the right side of the shot.
One minute it is sharp, the next it is soft.
I am stumped. Shutter speed was more than 1/60th, weirdly still the 100th-second shutter speed was worse for blur.
I am beginning to think that drones are not for me.
Am I being too fussy?
