- Joined
- May 6, 2022
- Messages
- 176
- Reaction score
- 111
- Age
- 49
Does anyone know how to plan a corridor mapping flight? Normally done by importing a KML centerline and then offsets are automatically created according to altitude and overlap requirements.
Mine is EVO RTK
1- drone does stop and turn but mine doesn't take long at all to do so, I will try to screen record this when I have a chance to see if it's the same as an enterprise.
2- Yes RTK disconnects when doing battery swap, you are correct, why?
3- I have never experienced a drop in altitude with the RTK version.
4- Not sure what you mean there? if you're talking about the last option in mapping mode, you can turn that off...
5- I haven't noticed this on my drone, not to say it is not, just haven't paid attention, you may be able to put overlap front overlap to 0, and put camera mode to shoot every 2 sec. just thinking off top of my head.
or reduce front overlap
So $150/yr to gain terrain following and corridor... if that's what linear is. Kind of a no brainer for us. It would be interesting to see how it holds the attitude of the drone. I'll check on a demo.Map Pilot Pro works with EVO
2- yes I agree, it should not disconnect being it's to the RC
I have the base package, but don't use it much due to I have not needed a corridor or terrain to follow, being where I live it's pretty flat until you hit the mountainsSo $150/yr to gain terrain following and corridor... if that's what linear is. Kind of a no brainer for us. It would be interesting to see how it holds the attitude of the drone. I'll check on a demo.
I guess that means I need a standard controller right?I have the base package, but don't use it much due to I have not needed a corridor or terrain to follow, being where I live it's pretty flat until you hit the mountains
the few times I did use it, it seemed to work well...
Yes if you want to use Map Pilot Pro unless there is something I don't know about. Just like DJI some apps are only available for IOSI guess that means I need a standard controller right?
Thanks Dave1. Yes, Autel's execution of turns is not good. They are aware of the issue (since at least August 2021) and have said it will be fixed but so far, nothing. Nothing the user can do about it.
2. Perhaps it drops the NTRIP connection because the gnss receiver in the drone goes off line. The internet connection is still there, but the rover is actually missing. Just spit balling because I don't have anything else to compare it to. Michael, on your other gear, does the NTRIP stay active if you power off the gnss receiver?
Map Pilot supports the Evo in a limited way. Last time I checked, MP did not recognize the Ent. model. This may have changed in a new FW that I have not installed.
Linear (Corridor) FlightWould Linear fall under this category? (corridor)
Also Map Pilot Pro is for Apple only, so you would need a regular remote and an Apple Tablet
Number 1 is not fixable. Will never be. Hardware does not support this type of programming.1. Yes, Autel's execution of turns is not good. They are aware of the issue (since at least August 2021) and have said it will be fixed but so far, nothing. Nothing the user can do about it.
So...forget about smooth turns like DJI have.
How does DroneDeploy do it? We've been running it for 7 years and 3 year's ago they changed to a completely different orientation and it is beyond any other that I have used in that time. I am trying to explain that it is an issue with how the aircraft approaches the target and the tolerance of the contact. It's not just the Evo II but it can be overcome on RTK for sure.Number 1 is not fixable. Will never be. Hardware does not support this type of programming.
