EVO 2 props
Do not have too much fun with this, keep the original elements which were designed by the manufacturers. I have bad memories of some who used propellers other than the original DJI one and the propellers broke in flight with the drone falling to pieces on the ground.
The game is too hot for a loss that costs over a thousand dollars.
@Ungava @claudius62 I agree 100%, do not use aftermarket props. The OEM props on drones underwent hundreds if not thousands of hours of testing, computer simulations, and were designed by some of the best aeronautical specialists in the industry. Aftermarket props undergo nowhere near the same attention to detail, testing, or safety.
Like @claudius62 said, carbon fiber props were in style for a few years and so were cheap aftermarket knockoffs. They added vibration to the drones, destroyed the drones when they struck things like tree branches because they were too stiff, and had a tendency to fall off or break in middair.
if and when master airscrew makes a prop for autel, I would buy it. otherwise, like others have said, don't try just any prop since it's risky; our drones are too expensive to go the cheap route.
Master Airscrew propellers had problems with the Mavic Dji, locked propellers became impossible to disassemble, the solution was to break the propeller hub with the risk of twisting the shaft and others had to return their drone to the After-sales service when it is impossible to do so.
So ... distrust.
hakles
