EVO 1 Renaissance YES New 6900 battery AVALIABLE on amazon
It looks taller, which would makes sense if its capacity is bigger, how much flight time are you getting from it?
Thank you for posting that. I am getting ready to sell my full Evo 1 kit and that information will help. I appreciate it!
Do not sell your EVO one because of range air time or bat unavail
Replacement for the evo one bat 4900.... with a 6900 COMPATIBLE...YES!!
A new 6900. This will make the simple EVO 1 a completely different Bird.
It looks like you can buy this battery from Maximal Power’s web store and get 15% off (lower than Amazon) and still get free shipping. They claim this battery is the same weight as the original Autel battery.
Thanks! I posted my Evo 1 for sale yesterday and have updated the links there. I appreciate the update!
I bought 3, look like...
Very good quality,
Compatible for Autel Robotics EVO Drone
Battery Capacity: 11.4V 6900 mAh
Type: Drone Battery
Item Dimensions: 4.5 x 2.1 x 2.45”
High Performance Li-Po Battery
Rated Capacity: 6900mAh, 78.66Wh
Nominal Voltage: 11.4V
Max Charge Voltage: 13.05V
MPN: DRB AUTEL EVO 6900
SKU: 2101
Replacement battery's weight is same as the original brand battery. Will not affect the flight moment.
Helico note...
This is NOT true , the Original autel weight 277 g and the GIFI weight 404 g. So it is 127 gram more heavy.
HELICO
Very good quality,
Type: Drone Battery
SKU: 2101
Helico note...
HELICO
Did you fly with this battery yet?
Not yet.
Here, where I live the weather and snow cover is too much for an 80 Y/O Old Body like me, to search/ and/ retreive, If the Bird do not RTH.
I use the Tracker Trackimo and I love it, but no thanks for using Snowtracks. I will wait a couple of month, I am not in a hurry.
Looking to the South for a Report.
PS ...EVO One is powerfull enough to fly with 127 Gr. on its Back....No Problem with that.
Helico
Not yet.
Helico
I thoroughly understand about the winter weather. I agree that the Evo 1 should be able to handle the extra weight. I do wonder how the extra weight might affect the Evo's center of gravity.
Thanks,
Mark
Thanks,
Mark
REPORTING
I Flew my EVO one with this 6900 mAh battery
Absolutly Amazing.............
I had 45 min SOLID flight time indicated before TakeOff
I flew 38 min, landed with 9 min left...
Control and manuvers like the original bat. No Problem AT All.
I am Flabergasted
I just want to only fly with those Bat. Unbeleivable.
I Hope This Help.
Helico
Reactions: Lyk2fly
Very good quality,
Type: Drone Battery
SKU: 2101
Helico note...
HELICO
REPORTING
I am Flabergasted
I Hope This Help.
Helico
Reactions: Lyk2fly
I am also in the process of buying them since I actually saw them on amazon but before buying them I would like to know who or know where to get the flexible gimbal roll plane because they gave me an evo 1 but it does not have that flex. I saw a Ukrainian youtuber who disassembled the gimbal and so I could see the flex and part number.​
REPORTING
I am Flabergasted
I Hope This Help.
Helico
UPDATE with my EVO 1 and 6900 Mah battery.
Before Take Off on the 3 first Flights bat indicate that 44 minutes plus time when Full Charge.
After 3 Flights it indicate around 40 min Avaliable.
After over 30 Flights , I can say that it is safe to Fly around 23 or 24 min.
I realy Love this Battery.
But WARNING, WARNING,WARNING,.....
The Battery separate in Flight, the attachement is Unreliable. (Had two Crashs)
I Strongly Suggest this Solution, NO more Crash. See Picture.
REPORTING
I am Flabergasted
I Hope This Help.
Helico
ghost183
