Thanks! Will try today and let you know.Delete the Explorer app on your phone.
Go HERE:
All Explorer App Versions, Firmwares, & Manuals
Download version 1.0.1,45apk
and install
I have that version and it work fine
Report back if you have problems
Can't figure out how to install the APK. My Android Phone is partitioned by Knox with a section for my Company using MS InTune. Although I download the APK to the personal section of my phone, it will not let me install due to administrator privileges' not being granted. Deleted the Explorer App, joined the Beta Testing version, downloaded again; same problem. No control on the App. This is version 1.1.7.83. I'm considering uninstalling the company inTune section of my phone and trying again; but what a pain!Thanks! Will try today and let you know.
Thanks for your help. Turned out the problem was the security on my phone. Once I uninstalled the work partition I was able to reinstall the apk.""There are so many firmware versions for different components, this becomes very confusing. I can't tell if I'm updating the controller or the aircraft!!!""
Remember that you have an EVO 1(per your post)
APK are Explorer apps
Bin Files are for the controller and EVO and Batteries
You should usually use the latest versions, unless you need a specific reason to use a older version
Quick question. Everything works perfectly except for the fact that the remote control no longer speaks. Any idea how to fix that?Thanks for your help. Turned out the problem was the security on my phone. Once I uninstalled the work partition I was able to reinstall the apk.
