Drop a pin to locate Drone?
Rossman
The other day I had a battery unknown issue and the drone started to descend and go out of my sight...into some trees. Luckily I was able to find it. I was curious if there was a way to drop a pin when I still have sight of the drone to better locate it.
If there is another way that would help find it in the future, I am open to that as well. Maybe in the flight logs?
Thanks for the help...
Ross
Ross
This sounds like you have a bad battery.
I would suggest you contact Autel for this matter. Even if the Evo is OK, I would want it checked out also.
To answer the question:
The map will be your best guess in this situation -- unless you look into third party tracking devices. In an instance the battery does not completely die -- it should update on your map it's positioning. (Unless no GPS signal is a problem)
It should show it's last coordinates in the logs even if it should go out of site and completely die.
Even then - unless you are using a tracking device -- it is only going to give you a best guess as for an area to search in.
