I am about to deep cycle my batteries for the first time (90 days since I got my Evo) and my plan is to take off and let it hover until it depletes. Will the Evo try to RTH or will it know it hasn't moved and stay there until it lands?
Thanks.When it is so close to you it will not kick in to RTH. If it is anything like the XSP the last few minutes you will have to have the left stick up to prevent it from landing and shutting off on you. I believe the say 7-8%. Your battery will bounce back a few voltages after it lands.
I will. I didn't take them from 100% to 12% though. Heh, guess I'll try again tomorrow.Funny that they have this in the manual. Maybe email them and ask how your suppose to get to 7%
We strongly recommend that you go through a charge cycle — wherein you charge the battery to 100% and then discharge it to 7% or lower — every three months, or after the battery has been used for 20 consecutive charges.
It's to windy for an enjoyable flight. Someone suggested to let it stay on the ground with the motors on, but those turn off after 60 seconds of no action.OK, the lazy way? Fly as long as you can/want to....land. Power-up and let it sit. That works with the XSP. You can monitor the % on the App while eating chicken wings or whatever...
Yes, as it is a LiPo battery, but the remote won't fall off the sky if not taken care of properly. The Evo will.Maybe a stupid question... would this be needed also for the remote controller battery?
I did not ment it as humor. The drone's LiPo batteries that have not had their proper maintenance have been known to break a cell mid flight, causing the drone to fall of the sky. I've read about many occurences throughout the different drone forums I participate in.The cycling and conditioning of the batteries I thought is so it'll last longer (???)... I see your response is in humor, but I not sure I totally understand why not conditioning the lipo batteries would cause the drones to fall out of the sky... I just thought the drone just won't have as long of flight time, for example...
Secondly, the RC WOULD fall out of the sky, if I find it dead for some reason, I'd throw it in the air into the woods... hence, knowing to and conditioning battery is something I do not plan to take lightly...
Oh, it may happen to a conditioned battery as well. The difference is that they last longer and you lower the posibility of it occuring. When you do proper maintenance, the battery loses over time it's capability of holding charge and eventually you will see your flights dont last as long. I've read somewhere that after 60 cycles, be wary of that battery and if you need to use it, inspect it constantly.This is good awareness, definitely... I am sure a lot of drone owners don't even know about this... However, at the same time, how many stories have you heard where the conditioned batteries still yield the same issue you described above?
I totally see your point/reminder though...
I don’t turn the motors on, I just let it sit powered on. The XSP gets warm, but the batteries slowly drain as far down as you dare to go...It's to windy for an enjoyable flight. Someone suggested to let it stay on the ground with the motors on, but those turn off after 60 seconds of no action.
The Evo gets pretty hot from sitting there. I'll see what I come up with tomorrow. Currently charging the batteries.
Just found out that the charging of the Evo batteries take longer than the Phantom's batteries, which are bigger.
I do the same but I record video at the same time. Great option if you want to do a time lapse.
The Evo autolands, no matter how much stick you put at 12%. So I wasn't able to take it down to 7%.
Won't my bird get hot?You don’t have to be flying for the Batteries to discharge, just set it on your desk and leave it on. Discharges fairly rapidly actually!
