If you upgraded to the new Low Noise Propellers on your Evo 2 then you probably realized it won't fit in the Rugged Bundle case with them installed. I trimmed mine with an exacto knife so they would fit.
There are only two spots that need to be cut to make it fit. They are on either side, right next to the round reliefs for the lower motors. I held my drone with the new propellers installed over the slot and used a marker to trace around the new protrusion. Then with the drone out of the way I cut along my marks. The material needs to be removed all the way down to the ledge beneath the propellers.
Now my drone fits with the new props installed and with no problem.
