Kinda….it’s called viewpoint.Is there any way to set and fly in a course lock orientation like I can do with my P4P? I've looked around and would be nice to able to do so.
I was using that method, manually crabbing the tree line, dropped down, camera tilt down to the lake, backed out of the shot. turned out great, BUT I was so focused on the shot I neglected to watch altitude!! when I seen the prop wash in the water I looked, 9.8ft!!!! Glad the brick didn't go into auto-land mode!the beauty comes in when you change the angles (direction and height) and adjust the speed. certainly this can be flown manually
that's fine if I am required to fly straight forward but at least I should be able to turn my camera to the side. the dji drone will do that simply by sliding your finger on the display and you can move the camera to an angle. iirc, we've been asking for that...for a long time.Yes, viewpoint will ONLY allow you to fly straight forward, not parallel or reverse. If you want to something like that you have to do manual. IMO Autel is doing a great job with adding feature in their updates and they are listening to their customers input.
Also you can try waypoints with POI ..That works great for shot compositionthat's fine if I am required to fly straight forward but at least I should be able to turn my camera to the side. the dji drone will do that simply by sliding your finger on the display and you can move the camera to an angle. iirc, we've been asking for that...for a long time.
I'm not a great manual flyer. instead, I start a mission and set a path ahead and lock in a waypoint behind me. the evo 2 is a great flyer, it will fly backward, and keep it's camera locked on target and this works well when the target it directly in front or directly in the rear.
to be fair, I haven't much tried to use viewpoint but now that I have a sc, I'm open to experimenting and making the best of built-in features already offered by autel.
yes, that is what I used. the target is actually a POI. still, autel needs a course lock feature. if you want to run your drone down the boardwalk while is one mile long straight and you don't want to/can't fly overhead but off to the side to see the shops as you pass by, how can you do that?Also you can try waypoints with POI ..That works great for shot composition
Hi Kenautelevo2pro,yes, that is what I used. the target is actually a POI. still, autel needs a course lock feature. if you want to run your drone down the boardwalk while is one mile long straight and you don't want to/can't fly overhead but off to the side to see the shops as you pass by, how can you do that?
this is what I would like:Hi Kenautelevo2pro,
Is not what you want called parallel track in the modes. Johnno.
Hi,this is what I would like:
hi john I am familiar with parallel track and unfortunately it's not the same. there is a parallel mode on the dji as well and it's there along with course lock because they are two different functions. parallel tracking cannot achieve what you get the course lock; it's similar but not quite. hopefully autel didn't think they were the same and left out course lock because I would much rather prefer the latter.Hi,
There is a mode in the EVO 2 called PARALLEL TRACK. It is in section 5.3 of the Autel Explorer app Manual . This shows you how to use it. Johnno Hennessy.
are you talking about viewpoint?Have you tried Cruise mode? I think it might be close to what you are looking for. I have not tried it. I did receive an answer from Autel that wasn't really clear, but this does keep the drone going in one direction while the camera controls are worked. It was not clear that this means the yaw could be adjusted and I am not sure if the elevation of the drone can be changed during this mode.
My follow up question to Autel about the Cruise mode resulted in this response:are you talking about viewpoint?
or cruise mode in manual
this isn't very easy to setup and use. I'm finding while my drone is "cruising" you can't make a lot of changes easily. I'm finding it impossible to turn the camera 90% even by aiming the entire drone (since the camera cannot move by itself). also, this is working during hyperlapse only not with ordinary video. I'll keep working on it but for now, I'm going to say this is not a suitable substitute for traditional course lock which would be so much more easier to implement. thanks for the help and let me know if I am doing something wrong.My follow up question to Autel about the Cruise mode resulted in this response:
"Cruise mode only allows you to YAW the aircraft to aim the camera and pitch the camera. If you wanted elevation changes, they need to be setup in the waypoints.
You can set either photos or videos in waypoints/cruise.
OA sensors are enabled, but please be aware OA is only made for assistance and not to be relied solely upon.
Press and hold the pause button to stop the mission."
Does this help?
Autel's Pro is still missing a basic Pro tool a year after release.this isn't very easy to setup and use. I'm finding while my drone is "cruising" you can't make a lot of changes easily. I'm finding it impossible to turn the camera 90% even by aiming the entire drone (since the camera cannot move by itself). also, this is working during hyperlapse only not with ordinary video. I'll keep working on it but for now, I'm going to say this is not a suitable substitute for traditional course lock which would be so much more easier to implement. thanks for the help and let me know if I am doing something wrong.
