camera tilt malfunction
qwesthunter
has anyone fixed a camera that does not want to tilt either way? everything else works great.
thanks for any help on this
Many times camera and/or gimbal issues have been solved with a cleaning of contacts on the Xteady R12 gimbal assembly. Remove and inspect contacts and all wiring and connectors. Use pencil eraser or cotton swab damp with alcohol to wipe contacts. Some times, a simple remove/replace of gimbal will do the trick, but if I take mine off, I clean the contacts.
Hope this helps.
