Camera adjustment 90° to TOP
Jockel2000
Hello,
did not I once heard that there is a setting on the app to turn the camera 90 ° UP ?
Can someone tell me where I can find this setting ?
Thanks
Hi Jockel2000,
if your question is not meant as a joke (have a look at the gimbal mechanically) you are unfortunately wrong... you can of course turn the gimbal 90° downwards via the programmable button on the remote control.
Best Regards
Wolfgang
Hello Wolfgang,
down yes, but I can't put the gimbal up. Straight up yes, but I thought you can operate some function that the gimbal can also look up.
function key can be programmed to set/reset the gimbal position, click to look straight downward and click again to 0 degree.
If you are looking for -30 deg upward, this is it
thank you, that was what I was looking for
chuckster58
