- Joined
- Sep 29, 2021
- Messages
- 8
- Reaction score
- 6
- Age
- 64
You can turn the built in bottom light on to take of being seen from below via the explorer app, turn from auto to flash 1 sec or flash 2 sec. Another option is to put velcro on battery and attach to back of battery.Don't you want it on the bottom instead? So you can actually see it?
No. The light is required for night time operations so that aircraft above me (like helicopters) can see the UAS. I don't have the text in front of me but I think the requirement is that it be on top.Don't you want it on the bottom instead? So you can actually see it?
I want to Velcro a Lume Cube Anti-Collision Light to the top of my EVO II Pro v2 but I don't want to put it in a location which might interfere with GPS connectivity or anything else. Is the location in the attached picture safe to use?
Thank you. I will read that thread. Also, I folder some tin foil into a 2x2 inch square and moved it around the top surface of the Evo II Pro while looking at the GPS signal on the remote. Doing that really helps demonstrate where the GPS antenna is. And, like I was told earlier today by another user I'll mount the light (using industrial Velcro) as far front as feasible.This was discussed in some detail in this thread. Long story short, your chances if interfering with the GPS is next to none no matter where you mount it and in that thread I also provide some easy ways to prove it/test it before you attach it with Velcro.
.The light is required for night time operations so that aircraft above me (like helicopters) can see the UAS.
For the US:Interesting, thanks.
Is it a legal requirement? Or just an advisory / recommendation?
Which country are you in?
please clarify if part 107 regulations such as 107.29(2) apply to recreational pilots.For the US:
There is not a legal requirement as to where the flash strobe is located other than the aircraft/UAS e.g. drone has to be visible from at least 3 statue miles. Good practice would be to place strobes so can be seen from different directions.
Here's the current rules, regulations, specificly:
107.29(2) Operations at night.
"The small unmanned aircraft has lighted anti-collision lighting visible for at least 3 statute miles that has a flash rate sufficient to avoid a collision. The remote pilot in command may reduce the intensity of, but may not extinguish, the anti-collision lighting if he or she determines that, because of operating conditions, it would be in the interest of safety to do so."
Good question, as a recreational pilot can you fly at night and do you need to have lights on your aircraft? Yes.please clarify if part 107 regulations such as 107.29(2) apply to recreational pilots.
It's not intended for you to see, it's for other Aircraft to see...NO, that is where the GPS antenna is located. Move forward as far as you can, would be best.
I think this thread is drifting off topic. I prefer the light on top so local helicopter traffic which may be flying quite low will have an opportunity to see the drone's strobe from 3 miles away. I'm not flying in restricted airspace, but there is occasional helicopter traffic from air-medivac and nighttime utility inspection (infrared scanning for steam leaks), etc.To what end?
Even if they could see a tiny 3mm wide LED light from that distance, at that approach speed, an aircraft is not going to change course to avoid a drone?
sorry im still confused, you answered a lot of questions i already thought i knew except the one i don't know for sure: as recreational pilot, am i required by law to display a qualified strobe light on my drone when flying at night? i know what i do which is yes i use a strobe, my question is am i breaking the law if i do not? i've heard so many different answers and i realize the situation is always changing over the months and years but wanted to get your take on it.Good question, as a recreational pilot can you fly at night and do you need to have lights on your aircraft? Yes.
Do part 107 pilots still need a daylight waiver? No, however you have to have taken the new 107 free online recurrency test to fly at night now, as well as have lights on your aircraft.
Recreational pilots fall under 44809 and its rules (see here) which are a "carve out" which also include those of the community based organization (CBO) being flown under. So here's the catch, normally if as a recreational pilot you are flying under the 44809 rules or those of a CBO, you would not be flying under 107 rules, likewise you can not apply for waivers or special airspace authorizations such as flying above published altitudes (this includes not flying higher than 400' when within 400' of a structure), or in NFZs.
As an fyi, fwiw, The Recreational UAS Safety Test (TRUST) for recreational flyers is online and free, check if out if you have not done so already. Also visit the FAA Safety site (e.g. faasafety.gov) which has a ton of information, tutorials and links for UAS as well as regular aircraft and related topics.
i agree and in fact, if a manned aircraft has to divert in order to avoid a collision with your drone (which may or may not be in the path), that's not going to be a good outcome for the drone pilot.To what end?
