- Joined
- May 9, 2021
- Messages
- 150
- Reaction score
- 61
- Age
- 67
Yes - you need to insert all the batteries into the EVO II and re-run the update: it won't take as long as the first update, but is still necessary. Also best to cycle through all of your batteries you are flying with - to ensure such updates are applied evenly and not missed for some of your batteries.I have an evo 2 with 5 batteries. I’ve been using the same 1-2 batteries when I need to fly it. Question is. Do I need to do a firmware update for every battery? I’ve only updated firmware once when I got it. Never did with the other batteries.
I think you mentioned you fly with the same 1-2 batteries. if you don't fly with the other 3 batteries, there is no need to update them.I have an evo 2 with 5 batteries. I’ve been using the same 1-2 batteries when I need to fly it. Question is. Do I need to do a firmware update for every battery? I’ve only updated firmware once when I got it. Never did with the other batteries.
I got all the batteries updated. I will start to rotate use.However if those other 3 batteries are sitting idle for months at a time, this will decrease their longevity. Better to run all 5 batteries and simply log the number of cycles on each to give all of them regular use.
to my knowledge, this is nothing preventing the drone from flying with a battery that doesn't have the most current update. autel doesn't sell v1 and v2 batteries.I've got a related question. I currently have (2) EVO II Pro 6K's a V1 & a V2. If I perform a firmware update for the batteries on the V2 will I still be able to use the batteries in the V1? I suspect I already know the answer & I probably won't like the answer! Is or will there be a path to get the batteries back to working order with the other bird?
What exactly is being updated/changed in the battery update and what are the consequences for not updating the batteries firmware?
Ken, thanks for the reply. I realize that Autel only sells one battery and they work in both models. However, I do not believe firmware is sync'd between the V1 & V2. So, if I update all (4) of my batteries to the latest V2 Firmware, will they become unusable in my V1?to my knowledge, this is nothing preventing the drone from flying with a battery that doesn't have the most current update. autel doesn't sell v1 and v2 batteries.
correct, the software on a v1 drone is different than the software on a v2 drone. my guess is when you buy a battery from the retailer today, it works with either a v1 drone or a v2 drone regardless. my reasoning is a battery that you purchased today comes with software that is already updated with the v2 and since it is not marked as a v2-only battery, stands to reason it will work with v1 equipment. have you checked the version after updating just one battery to see if at least the number has changed? i would try with just one battery first and see if it works on both v1 and v2. if it does not, i'm sure autel will take care of it for you since this shouldn't be happening without warning from autel.Ken, thanks for the reply. I realize that Autel only sells one battery and they work in both models. However, I do not believe firmware is sync'd between the V1 & V2. So, if I update all (4) of my batteries to the latest V2 Firmware, will they become unusable in my V1?
I have not updated any of the batteries yet. I am firmware "Gun Shy" at the moment after recently experiencing a firmware update problem that required sending my drone & controller to Autel to straighten things out (10 days later). The official statement from Autel was that the wrong version of firmware was used. This started by the automated over the air firmware update which failed and then followed up with a manual attempt and there is no question that the appropriate links on the website were followed to get to what was supposed to be the correct firmware. Thanks for your reply!correct, the software on a v1 drone is different than the software on a v2 drone. my guess is when you buy a battery from the retailer today, it works with either a v1 drone or a v2 drone regardless. my reasoning is a battery that you purchased today comes with software that is already updated with the v2 and since it is not marked as a v2-only battery, stands to reason it will work with v1 equipment. have you checked the version after updating just one battery to see if at least the number has changed? i would try with just one battery first and see if it works on both v1 and v2. if it does not, i'm sure autel will take care of it for you since this shouldn't be happening without warning from autel.
