The
EVO 2 Battery weight vs flight time seems already pretty well optimised if you ask me. Any added weight will reduce flight time and also could cause an offset in the center of gravity too. So the IMU will have more activity going on to keep the drone in balance. Hence more energy will get consumed for keeping the aircraft stable. I therefore doubt if adding aux-batteries on the sides or under the aircraft would even have any significant increase in operation time, be it hovering or a longer range in distance back and forth. Apart from that anything added to the aircraft like the official Propeller Guards or the accessories such as available for the
EVO 2 Enterprise, reduce the total aerodynamics a lot. Increase of weight + less aerodynamics will probably out rule the benefit of added aux power.
Still I remain curious to hear if anyone has experimented with this. Send some proof if such aux power hacks exist and when they do show beneficial results.
