Autel Robotics EVO II PRO RTK V3 no custom ntrip option
Manny58200
Hi we bought a Autel Robotics EVO II PRO RTK V3 from amazon and in the listing it said the below. I was under the impression we could use our Trimble bases to send our ntrips to these drones. We are able to setup a ntrips and connect with our rovers and other equipment so we know the Trimble is working correctly. We used the below link that walks you through the process but our controller doesn't have the custom network option. Is this our problem and how do we fix it?
I am just getting started on trying to connect the same drone to a Trimble SPS986. I have had it connected to anEmlid RS2 with no problems. I am just looking to streamline my process.
Currently, I use a pair of Topcon Hiper VRs to calibrate the site, shoot my GCPs, and check shots. I then set up the Emlid on a "here now" position and use their ntrip caster service. I am just looking for the missing link between the Trimble and Autel. My SPS986 has Centerpoint corrections and I'm hoping to be able to shoot GCPs and check shots and then shift it over to broadcast corrections to the drone. I guess I am assuming the Trimble SPS986 is a better base than the Emlid and that may be wrong.
Have you come up with any solutions?
RailHawk2018
